I get lots of weird errors; I was trying to start a clean backup but even that is not working.
purge broken gives:
Found 5 commands but expected 1, commands: “s3s://tdqtoxehjljs_fqkihih-backup/?s3-server-name=objects-us-west-1.dream.io&s3-location-constraint=&s3-storage-class=&auth-username=TDqtoXehJLjs_FqKIHIh&auth-password=oQjcAbpexHYcGmlV5EerJVHI_kz8jeJ9y-6zA-Bx&accept-any-ssl-certificate=true” “C:\Users\jenge\Pictures” “C:\Users\jenge\Documents” “C:\Users\jenge\SourceCode” “C:\Users\jenge\Sites”
Return code: 200
could my config file be bad?
purge all fails because one orphaned file. Does that mean I have one extra file that should not be on the cloud?
Duplicati - 2.0.3.1_experimental_2018-03-16 running on windows 10 saving to dream objects. I connect to the cloud, I can rebuild database; and verify files. something from the logs:
Expected there to be a temporary fileset for synthetic filelist (16, duplicati-b00ad6ef960cc48af9cc9de81ca1a69c1.dblock.zip.aes), but none was found?
The exact file name is different each day. also some days its an index this time it was a block.
