------ Resolved ------
Hey,
We’re having an awful time getting 700GB backed up on a Windows 7 32bit machine running Duplicati Beta as a service (Canary didn’t help). It is backing up a Windows Server 2003 machine over a SMB mounted drive
It gets through a sizable portion of the backup, then throws this error:
Another error it throws is this:
System.AggregateException: One or more errors occurred. ---> System.AggregateException: '0' is an unexpected token. The expected token is '"' or '''. Line 2, position 33. ---> System.Xml.XmlException: '0' is an unexpected token. The expected token is '"' or '''. Line 2, position 33.
at Duplicati.Library.Main.BackendManager.List()
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)
at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext()
at Duplicati.Library.Main.Controller.<>c__DisplayClass13_0.<Backup>b__0(BackupResults result)
---> (Inner Exception #0) System.AggregateException: '0' is an unexpected token. The expected token is '"' or '''. Line 2, position 33. ---> System.Xml.XmlException: '0' is an unexpected token. The expected token is '"' or '''. Line 2, position 33.
---> (Inner Exception #0) System.Xml.XmlException: '0' is an unexpected token. The expected token is '"' or '''. Line 2, position 33.
at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext()<---
---> (Inner Exception #1) System.AggregateException: One or more errors occurred. ---> System.Exception: Unable to find log in lookup table, this may be caused by attempting to transport call contexts between AppDomains (eg. with remoting calls)
at Duplicati.Library.Logging.Log.get_CurrentScope()
at Duplicati.Library.Logging.Log.WriteMessage(LogMessageType type, String tag, String id, Exception ex, String message, Object[] arguments)
at Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess.<>c.<Run>b__1_3(String rootpath, String errorpath, Exception ex)
at Duplicati.Library.Utility.Utility.<EnumerateFileSystemEntries>d__23.MoveNext()
at System.Linq.Enumerable.<SelectManyIterator>d__17`2.MoveNext()
at Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess.<ExpandWorkList>d__4.MoveNext()
at Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess.<>c__DisplayClass1_0.<<Run>b__0>d.MoveNext()
at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
---> (Inner Exception #0) System.Exception: Unable to find log in lookup table, this may be caused by attempting to transport call contexts between AppDomains (eg. with remoting calls)
at CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()<---
Couldn’t find anything online regarding this, any ideas where the issue might be?
Thanks!
Edit: Looks like the seafile storage I was backing up to was corrupt, an FSK fixed it. Seemed to happen a lot, very large duplicati backups can be hard to finish
