I’m getting this once in a while during backups to a local NAS.
Edit: Now the exact backup job copy to a remote NAS has the same “hickup”. So it has nothing to do with location local or remote… hmm.
The backup is running every 4 hours and this error pops up every now and then (sometimes once a day, sometime twice).
It seems to pop up during the backup and the backup seems not to be finished sucessfully.
I found another topic for this, but the details are different…
Oh, and i get this only during this particular backup. 3 others (same destination NAS, other folder) are running fine.
Can anyone shed a light on the meaning of this?
Failed: Unexpected number of remote volumes detected: 0!
Details: System.Exception: Unexpected number of remote volumes detected: 0!
bei Duplicati.Library.Main.Database.LocalDatabase.UpdateRemoteVolume(String name, RemoteVolumeState state, Int64 size, String hash, Boolean suppressCleanup, TimeSpan deleteGraceTime, IDbTransaction transaction)
bei Duplicati.Library.Main.Database.LocalDatabase.UpdateRemoteVolume(String name, RemoteVolumeState state, Int64 size, String hash, Boolean suppressCleanup, IDbTransaction transaction)
bei Duplicati.Library.Main.Operation.BackupHandler.FinalizeRemoteVolumes(BackendManager backend)
bei Duplicati.Library.Main.Operation.BackupHandler.Run(String[] sources, IFilter filter)
bei Duplicati.Library.Main.Controller.<>c__DisplayClass16_0.b__0(BackupResults result)
bei Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action`1 method)
PS: hope i did format the output right?
