I’ve got some issue here with Duplicati, in the log files it keeps giving me the following;
Failed: Setting multiple retention options (--keep-time, --keep-versions) is not permitted
Details: Duplicati.Library.Interface.UserInformationException: Setting multiple retention options (--keep-time, --keep-versions) is not permitted
at Duplicati.Library.Main.Controller.ValidateOptions () [0x000ab] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Controller.SetupCommonOptions (Duplicati.Library.Main.ISetCommonOptions result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter) [0x004f0] in <60a7e79acb3b49e8af8a73149919d15b>:0
at Duplicati.Library.Main.Controller.RunAction[T] (T result, System.String[]& paths, Duplicati.Library.Utility.IFilter& filter, System.Action`1[T] method) [0x00072] in <60a7e79acb3b49e8af8a73149919d15b>:0
I never set --keep-time
and/or --keep-versions
together, I only set one of these option and that was just --keep-versions
I checked my config and it doesn’t even have both of these settings enabled, only one of them. How can I force it to recognise from the config that only one of them is set and not both? I only want/need --keep-versions
for keeping backups of up to 3 months at a time.
