Export all existing configurations
Thanks for the updated script! 2.1 adds another method:
ServerUtil
C:\Program Files\Duplicati 2>Duplicati.CommandLine.ServerUtil export --help
Description:
  Export a backup configuration
Usage:
  Duplicati.CommandLine.ServerUtil export <backups>... [options]
Arguments:
  <backups>  The backup id or name to export, use 'all' to export all backups
Options:
  --encryption-passphrase <encryption-passphrase>      The passphrase to use for encrypting the backup configuration []
  --export-passwords                                   Flag toggling the inclusion of sensitive values, such as passwords, defaults to true if a passphrase is supplied []
  --overwrite                                          Flag toggling the overwriting of existing files [default: False]
  --unencrypted                                        Flag toggling unencrypted export of configurations [default: False]
  --destination <destination>                          The folder where the backup configuration should be exported to [default: C:\Program Files\Duplicati 2]
  --password <password>                                The password to use for connecting to the server []
  --hosturl <hosturl>                                  The host URL to use [default: http://localhost:8200/]
  --server-datafolder <server-datafolder>              The server datafolder to use for locating the database []
  --settings-file <settings-file>                      The settings file to use []
  --insecure                                           Accepts any TLS/SSL certificate (dangerous) [default: False]
  --settings-encryption-key <settings-encryption-key>  The encryption key to use for the settings file. Can also be supplied with environment variable SETTINGS_ENCRYPTION_KEY []
  --secret-provider <secret-provider>                  The secret provider to use for reading secrets []
  --secret-provider-cache <InMemory|None|Persistent>   The secret provider cache to use for reading secrets [default: None]
  --secret-provider-pattern <secret-provider-pattern>  The pattern to use for the secret provider [default: $]
  --host-cert <host-cert>                              The SHA1 hash of the host certificate to accept. Use * for any certificate, same as --insecure (dangerous) []
  -?, -h, --help                                       Show help and usage information
