I’m having trouble pinning down the location of a “bad” file. According to Duplicati, my backups are essentially halted because one file has an invalid timestamp. The trouble is, I don’t know how to find the file that’s causing this! Here’s what I see in “http://localhost:8200/ngax/index.html#/log”:
System.ArgumentOutOfRangeException: Not a valid Win32 FileTime.
Parameter name: fileTime
at Duplicati.Library.Main.BackendManager.List()
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, IEnumerable1 protectedFiles) at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, IEnumerable1 protectedFiles)
at Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.b__0(BackupResults result)
If anyone knows how I can find out more to resolve this, that would be excellent. This is a serious problem that I need to address quickly.
Interesting, looks like it’s getting this error when checking your back end files. What type of back end are you using (what protocol)? Can you try to manually view the files on the back end? Try sorting by date and looking for anomalous dates near the start or end of the list.
Since a few days I get the same (or a similar) error:
2022-01-13 15:55:14 +01 - [Error-Duplicati.Library.Main.Controller-FailedOperation]: The operation Backup has failed with error: Not a valid Win32 FileTime.
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, IEnumerable`1 protectedFiles)
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, IEnumerable`1 protectedFiles)
My backend is a Linux Samba Server (actually with ZFS and the Samba ZFS sharing enabled).
The date range of files in that directory is from November 2020 to 8th January 2020 (the last day the backup was working)
I tried the code from that callstack on my directory and the LastWriteTime (shown by ls in linux and in Windows Explorer by default) is fine. But when accessing LastAccessTime I get the exact same exception for a some files.
For some files the LastAccessTime is just empty (but only one file throws that exception)
Last time the “Last Access Time” was missing and i could fix it with touch -a but now on each backup new files are created without “Last Access Time” so I cannot fix it in between backups.
