Duplicati stopped working with SshException error
I’ve just recently starting using Duplicati on a Windows 10 box, connecting to a Linux server via ssh for backup. Everything was working fine for a few days but now I can no longer backup. I’ve tried repairing the database (fails for the same reason) and testing the connection (works fine). The log shows the following exception:
Failed while executing “Backup” with id: 1
Renci.SshNet.Common.SshException: Failure
at Duplicati.Library.Main.BackendManager.Delete(String remotename, Int64 size, Boolean synchronous)
at Duplicati.Library.Main.Operation.FilelistProcessor.RemoteListAnalysis(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)
at Duplicati.Library.Main.Operation.FilelistProcessor.VerifyRemoteList(BackendManager backend, Options options, LocalDatabase database, IBackendWriter log, String protectedfile)
at Duplicati.Library.Main.Controller.<>c__DisplayClass16_0.b__0(BackupResults result)
Restarting the service doesn’t help either.
The backup destination works fine when connecting through command-line ssh (e.g. cygwin).
Any suggestions for how to troubleshoot or get backup working again?
I’ll also note that on the target/destination Linux system, I see a successful ssh key-based login each time Duplicati tries to connect, so the failure point isn’t there.
Are you using a CoW (Copy on Write) format such as ZFS or Btrfs on your Linux destination?
If so, then the reason it worked for a while then stopped working is that you might be running into this issue:
The Linux destination is a volume-encrypted Veracrypt drive. I don’t think that is CoW, but in any event there are 7 TB free.
Your tip lead me to the solution, though. The Veracrypt drive needed to be remounted–something had gone awry. Perhaps Duplicati could provide a more informative error message? It looked like an ssh error but it was actually a target-disk mount issue.
Good job catching the issue. I flagged your post as the solution.
@kenkendk would likely know better than I but I suspect a generic error is coming out of the SSH protocol so Duplicati likely can’t get any specifics about why it failed.
I don’t think there is anything I can do. The error is from the SSH server that fails, and it does not tell why it fails.
That said, the error message “Failure” could probably be clearer :grimacing: but that is something that should be fixed in the SSH library.
Can’t the library distinguish between a failed ssh connection versus something that fails after an ssh connection is successfully opened?
