Is it possible to script the Duplicati installation?
I’d like to set the installer to not install a desktop shortcut, or a start menu shortcut and not start on startup.
Instead of running the MSI, you can extract files from the Zip version and copy them to a location of your choice.
For the record, I did use the zip version and was able to write a batch file that does the complete install including downloading the files. Thanks for your help!
Good to hear! If the kees-z post worked for you consider flagging it as the solution by clicking the checkmark icon.
Hi there
Would you be so kind to post the code for that .bat ?
Thank you
