I’m running Duplicati 2.0.4.5_beta_2018-11-28 on Windows Server 2016 Standard. Not as service, just running in systray. Backing up to Minio on a Debian machine.
For a while now Duplicati quite often crashes during backup resulting in Duplicati disappearing from the systray so I need to start i again. I had a similar problem a year ago where one single file on the backup server was unreadable due to a disk error.
But this time I’ve run DuplicatiVerify.py and it doesn’t complain about any file being broken or wrong, it just complains about a ton of files missing which I really don’t understand at all?
Last time I had a similar problem I made a special version of DuplicatiVerify.py that doesn’t crash when a file is unreadable but instead reports "“Can’t read file chunk” which did not happen now at all but did last time when a file was unreadable.
DuplicatiVerify_hack.zip (1.2 KB)
The result of the check is here verify.zip (1.8 MB) which reports:
160 dlist “File missing”
14 dlist “Verifying file”
79054 dblock “File missing”
23296 dblock “Verifying file”
The mail(!!) I get when it crashes is this:
Failed: A WebException with status ConnectFailure was thrown.
Details: Amazon.Runtime.AmazonServiceException: A WebException with status ConnectFailure was thrown. ---> System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 192.168.13.220:31210
at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception)
at System.Net.HttpWebRequest.GetResponse()
at Amazon.Runtime.Internal.HttpRequest.GetResponse()
at Amazon.Runtime.Internal.HttpHandler`1.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.RedirectHandler.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.Unmarshaller.InvokeSync(IExecutionContext executionContext)
at Amazon.S3.Internal.AmazonS3ResponseHandler.InvokeSync(IExecutionContext executionContext)
at Amazon.Runtime.Internal.ErrorHandler.InvokeSync(IExecutionContext executionContext)
at Duplicati.Library.Main.AsyncDownloader.AsyncDownloaderEnumerator.AsyncDownloadedFile.get_TempFile()
at Duplicati.Library.Main.Operation.CompactHandler.DoCompact(LocalDeleteDatabase db, Boolean hasVerifiedBackend, IDbTransaction& transaction, BackendManager sharedBackend)
at Duplicati.Library.Main.Operation.DeleteHandler.DoRun(LocalDeleteDatabase db, IDbTransaction& transaction, Boolean hasVerifiedBacked, Boolean forceCompact, BackendManager sharedManager)
at Duplicati.Library.Main.Operation.BackupHandler.CompactIfRequired(BackendManager backend, Int64 lastVolumeSize)
at Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__19.MoveNext()
at Duplicati.Library.Main.Controller.<>c__DisplayClass13_0.<Backup>b__0(BackupResults result)
Log data:
2019-05-27 12:35:41 +02 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
Not sure what I could do next to verify if any file is faulty. Is there any new way of checking, maybe this one is obsolete? And also still a bit odd that Duplicati crashes totally on whatever is wrong?
