I have a job where the target is a share in the local windows network.
If I have Duplicati 2.0.5.1 and I execute
Duplicati.CommandLine.BackendTool.exe GET "file://\\hulk\backup_rw\duplicati\local-03_hulk_data" duplicati-b4d2dfe9739124b1292308bcf3e0016d4.dblock.zip.aes
the file is correctly dowloaded
If I execute the same command on the same machine in the directory of Duplicati 2.0.6.3 I get this error
Command failed: Die Datei "\\?\duplicati-b4d2dfe9739124b1292308bcf3e0016d4.dblock.zip.aes" konnte nicht gefunden werden.
System.IO.FileNotFoundException: Die Datei "\\?\duplicati-b4d2dfe9739124b1292308bcf3e0016d4.dblock.zip.aes" konnte nicht gefunden werden.
Dateiname: "\\?\duplicati-b4d2dfe9739124b1292308bcf3e0016d4.dblock.zip.aes"
bei System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
bei System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite, Boolean checkHost)
bei Duplicati.CommandLine.BackendTool.Program.RealMain(String[] _args)
[Englisch: The file ... could not be found. Filename: "\\?\..."]
I read the “file://\\…” part from the Duplicati database (table Backup, column TargetURL) and the filename is from the job db.
With google:-, dropbox:-, webdav:-URLs everything is working. I just have problems with file:-URLs.
Also tried the “normal windows style” \\hulk\backup_rw\… with double backslash at the beginning and single backslashes.
The backup itself is also executed from the command line of this machine and works without any problem.
"C:\Program Files\Duplicati 2\Duplicati.CommandLine.exe"
backup
"file://\\hulk\backup_rw\duplicati\local-15_hulk_sitwork"
"\\hulk\fulldata_r\......\\" and so on
Is there a bug in the Backendtool with file-URLs or do I make any mistake in the usage?
