- using System;
- using System.Collections;
- using System.Collections.Generic;
- using System.IO;
- using System.Linq;
- using System.Net;
- using System.Text;
- using System.Text.RegularExpressions;
- using DnsLib;
- using Duplicati.Library.Interface;
- using Duplicati.Library.Logging;
- using Duplicati.Library.Utility;
- using System.Net.NetworkInformation;
- using System.Net.Sockets;
- using MailKit.Net.Smtp;
- using MimeKit;
- using Duplicati.Library.Modules.Builtin.ResultSerialization;
- namespace Duplicati.Library.Modules.Builtin
- public class SendMail : ReportHelper
- /// <summary>
- /// The tag used for logging
- /// </summary>
- private static readonly string LOGTAG = Logging.Log.LogTagFromType<SendMail>();
- #region Option names
- /// <summary>
- /// Option used to specify server url
- /// </summary>
- private const string OPTION_SERVER = "send-mail-url";
- /// <summary>
- /// Option used to specify server username
- /// </summary>
- private const string OPTION_USERNAME = "send-mail-username";
- /// <summary>
- /// Option used to specify server password
- /// </summary>
- private const string OPTION_PASSWORD = "send-mail-password";
- /// <summary>
- /// Option used to specify sender
- /// </summary>
- private const string OPTION_SENDER = "send-mail-from";
- /// <summary>
- /// Option used to specify recipient(s)
- /// </summary>
- private const string OPTION_RECIPIENT = "send-mail-to";
- /// <summary>
- /// Option used to specify mail subject
- /// </summary>
- private const string OPTION_SUBJECT = "send-mail-subject";
- /// <summary>
- /// Option used to specify mail body
- /// </summary>
- private const string OPTION_BODY = "send-mail-body";
- /// <summary>
- /// Option used to specify mail level
- /// </summary>
- private const string OPTION_SENDLEVEL = "send-mail-level";
- /// <summary>
- /// Option used to specify if reports are sent for other operations than backups
- /// </summary>
- private const string OPTION_SENDALL = "send-mail-any-operation";
- /// <summary>
- /// Option used to specify what format the result is sent in.
- /// </summary>
- private const string OPTION_RESULT_FORMAT = "send-mail-result-output-format";
- /// <summary>
- /// Option used to set the log level for mail reports
- /// </summary>
- private const string OPTION_LOG_LEVEL = "send-mail-log-level";
- /// <summary>
- /// Option used to set the log filters for mail reports
- /// </summary>
- private const string OPTION_LOG_FILTER = "send-mail-log-filter";
- /// <summary>
- /// Option used to set the maximum number of log lines
- /// </summary>
- private const string OPTION_MAX_LOG_LINES = "send-mail-max-log-lines";
- #endregion
- #region Option defaults
- /// <summary>
- /// The default mail sender
- /// </summary>
- private const string DEFAULT_SENDER = "no-reply";
- #endregion
- #region Private variables
- /// <summary>
- /// The server url to use
- /// </summary>
- private string m_server;
- /// <summary>
- /// The server username
- /// </summary>
- private string m_username;
- /// <summary>
- /// The server password
- /// </summary>
- private string m_password;
- /// <summary>
- /// The mail sender
- /// </summary>
- private string m_from;
- /// <summary>
- /// The mail recipient
- /// </summary>
- private string m_to;
- #endregion
- #region Implementation of IGenericModule
- /// <summary>
- /// The module key, used to activate or deactivate the module on the commandline
- /// </summary>
- public override string Key { get { return "sendmail"; } }
- /// <summary>
- /// A localized string describing the module with a friendly name
- /// </summary>
- public override string DisplayName { get { return Strings.SendMail.Displayname;} }
- /// <summary>
- /// A localized description of the module
- /// </summary>
- public override string Description { get { return Strings.SendMail.Description; } }
- /// <summary>
- /// A boolean value that indicates if the module should always be loaded.
- /// If true, the user can choose to not load the module by entering the appropriate commandline option.
- /// If false, the user can choose to load the module by entering the appropriate commandline option.
- /// </summary>
- public override bool LoadAsDefault { get { return true; } }
- /// <summary>
- /// Gets a list of supported commandline arguments
- /// </summary>
- public override IList<ICommandLineArgument> SupportedCommands
- get
- return new List<ICommandLineArgument>(new ICommandLineArgument[] {
- new CommandLineArgument(OPTION_RECIPIENT, CommandLineArgument.ArgumentType.String, Strings.SendMail.OptionRecipientShort, Strings.SendMail.OptionRecipientLong),
- new CommandLineArgument(OPTION_SENDER, CommandLineArgument.ArgumentType.String, Strings.SendMail.OptionSenderShort, Strings.SendMail.OptionSenderLong, DEFAULT_SENDER),
- new CommandLineArgument(OPTION_SUBJECT, CommandLineArgument.ArgumentType.String, Strings.SendMail.OptionSubjectShort, Strings.SendMail.OptionSubjectLong(OPTION_BODY), DEFAULT_SUBJECT),
- new CommandLineArgument(OPTION_BODY, CommandLineArgument.ArgumentType.String, Strings.SendMail.OptionBodyShort, Strings.SendMail.OptionBodyLong, DEFAULT_BODY),
- new CommandLineArgument(OPTION_SERVER, CommandLineArgument.ArgumentType.String, Strings.SendMail.OptionServerShort, Strings.SendMail.OptionServerLong),
- new CommandLineArgument(OPTION_USERNAME, CommandLineArgument.ArgumentType.String, Strings.SendMail.OptionUsernameShort, Strings.SendMail.OptionUsernameLong),
- new CommandLineArgument(OPTION_PASSWORD, CommandLineArgument.ArgumentType.String, Strings.SendMail.OptionPasswordShort, Strings.SendMail.OptionPasswordLong),
- new CommandLineArgument(OPTION_SENDLEVEL, CommandLineArgument.ArgumentType.String, Strings.SendMail.OptionSendlevelShort, Strings.SendMail.OptionSendlevelLong(ParsedResultType.Success.ToString(), ParsedResultType.Warning.ToString(), ParsedResultType.Error.ToString(), ParsedResultType.Fatal.ToString(), "All"), DEFAULT_LEVEL, null, Enum.GetNames(typeof(ParsedResultType)).Union(new string [] { "All" }).ToArray()),
- new CommandLineArgument(OPTION_SENDALL, CommandLineArgument.ArgumentType.Boolean, Strings.SendHttpMessage.SendhttpanyoperationShort, Strings.SendHttpMessage.SendhttpanyoperationLong),
- new CommandLineArgument(OPTION_LOG_LEVEL, CommandLineArgument.ArgumentType.Enumeration, Strings.ReportHelper.OptionLoglevellShort, Strings.ReportHelper.OptionLoglevelLong, DEFAULT_LOG_LEVEL.ToString(), null, Enum.GetNames(typeof(Logging.LogMessageType))),
- new CommandLineArgument(OPTION_LOG_FILTER, CommandLineArgument.ArgumentType.String, Strings.ReportHelper.OptionLogfilterShort, Strings.ReportHelper.OptionLogfilterLong),
- new CommandLineArgument(OPTION_MAX_LOG_LINES, CommandLineArgument.ArgumentType.Integer, Strings.ReportHelper.OptionmaxloglinesShort, Strings.ReportHelper.OptionmaxloglinesLong, DEFAULT_LOGLINES.ToString()),
- new CommandLineArgument(OPTION_RESULT_FORMAT, CommandLineArgument.ArgumentType.Enumeration, Strings.ReportHelper.ResultFormatShort, Strings.ReportHelper.ResultFormatLong(Enum.GetNames(typeof(ResultExportFormat))), DEFAULT_EXPORT_FORMAT.ToString(), null, Enum.GetNames(typeof(ResultExportFormat))),
- protected override string SubjectOptionName => OPTION_SUBJECT;
- protected override string BodyOptionName => OPTION_BODY;
- protected override string ActionLevelOptionName => OPTION_SENDLEVEL;
- protected override string ActionOnAnyOperationOptionName => OPTION_SENDALL;
- protected override string LogLevelOptionName => OPTION_LOG_LEVEL;
- protected override string LogFilterOptionName => OPTION_LOG_FILTER;
- protected override string LogLinesOptionName => OPTION_MAX_LOG_LINES;
- protected override string ResultFormatOptionName => OPTION_RESULT_FORMAT;
- /// <summary>
- /// This method is the interception where the module can interact with the execution environment and modify the settings.
- /// </summary>
- /// <param name="commandlineOptions">A set of commandline options passed to Duplicati</param>
- protected override bool ConfigureModule(IDictionary<string, string> commandlineOptions)
- //We need at least a recipient
- commandlineOptions.TryGetValue(OPTION_RECIPIENT, out m_to);
- if (string.IsNullOrEmpty(m_to))
- return false;
- commandlineOptions.TryGetValue(OPTION_SERVER, out m_server);
- commandlineOptions.TryGetValue(OPTION_USERNAME, out m_username);
- commandlineOptions.TryGetValue(OPTION_PASSWORD, out m_password);
- commandlineOptions.TryGetValue(OPTION_SENDER, out m_from);
- if (string.IsNullOrEmpty(m_from))
- m_from = DEFAULT_SENDER;
- return true;
- #endregion
- #region Implementation of IGenericCallbackModule
- /// <summary>
- /// Sends the email message
- /// </summary>
- /// <param name="subject">The subject line.</param>
- /// <param name="body">The message body.</param>
- protected override void SendMessage(string subject, string body)
- var message = new MimeMessage();
- MailboxAddress mailbox;
- foreach (string s in m_to.Split(new[] { "," }, StringSplitOptions.RemoveEmptyEntries))
- if (MailboxAddress.TryParse(s.Replace("\"", ""), out mailbox))
- message.To.Add(mailbox);
- var mailboxToFirst = (MailboxAddress)message.To.First();
- string toMailDomain = mailboxToFirst.Address.Substring(mailboxToFirst.Address.LastIndexOf("@", StringComparison.Ordinal) + 1);
- string from = m_from.Trim().Replace("\"", "");
- if (from.IndexOf('@') < 0)
- if (from.EndsWith(">", StringComparison.Ordinal))
- from = from.Insert(from.Length - 1, "@" + toMailDomain);
- else
- from = string.Format("No Reply - Backup report <{0}@{1}>", from, toMailDomain);
- if (MailboxAddress.TryParse(from, out mailbox))
- message.From.Add(mailbox);
- message.Subject = subject;
- message.Body = new TextPart("plain") { Text = body, ContentTransferEncoding = ContentEncoding.EightBit };
- List<string> servers = null;
- if (string.IsNullOrEmpty(m_server))
- var dnslite = new DnsLib.DnsLite();
- var dnslist = new List<string>();
- //Grab all IPv4 addresses
- foreach (NetworkInterface networkInterface in NetworkInterface.GetAllNetworkInterfaces())
- try
- foreach (IPAddress dnsAddress in networkInterface.GetIPProperties().DnsAddresses)
- if (dnsAddress.AddressFamily == AddressFamily.InterNetwork)
- dnslist.Add(dnsAddress.ToString());
- catch (Exception ex) { Logging.Log.WriteExplicitMessage(LOGTAG, "DNSServerLookupFailure", ex, "Failed to get DNS servers from network interface"); }
- dnslist = dnslist.Distinct().ToList();
- // If we have no DNS servers, try Google and OpenDNS
- if (dnslist.Count == 0)
- // https://developers.google.com/speed/public-dns/
- dnslist.Add("8.8.8.8");
- dnslist.Add("8.8.4.4");
- //http://www.opendns.com/opendns-ip-addresses/
- dnslist.Add("208.67.222.222");
- dnslist.Add("208.67.220.220");
- var records = new List<MXRecord>();
- foreach (var s in dnslist)
- var res = dnslite.getMXRecords(toMailDomain, s);
- if (res != null)
- records.AddRange(res.OfType<MXRecord>());
- servers = records.OrderBy(record => record.preference).Select(x => "smtp://" + x.exchange).Distinct().ToList();
- if (servers.Count == 0)
- throw new IOException(Strings.SendMail.FailedToLookupMXServer(OPTION_SERVER));
- else
- servers = (from n in m_server.Split(new string[] { ";" }, StringSplitOptions.RemoveEmptyEntries)
- let srv = (n == null || n.IndexOf("://", StringComparison.OrdinalIgnoreCase) > 0) ? n : "smtp://" + n
- where !string.IsNullOrEmpty(srv)
- select srv).Distinct().ToList();
- Exception lastEx = null;
- string lastServer = null;
- foreach (var server in servers)
- if (lastEx != null)
- Logging.Log.WriteWarningMessage(LOGTAG, "SendMailFailedWillRetry", lastEx, Strings.SendMail.SendMailFailedRetryError(lastServer, lastEx.Message, server));
- lastServer = server;
- try
- using (MemoryStream ms = new MemoryStream())
- try
- using (var client = new SmtpClient(new MailKit.ProtocolLogger(ms)))
- client.Timeout = (int)TimeSpan.FromMinutes(1).TotalMilliseconds;
- // Backward compatibility fix for setup prior to using MailKit
- var uri = new System.Uri(server);
- if (uri.Scheme.ToLowerInvariant() == "tls")
- uri = new System.Uri("smtp://" + uri.Host + ":" + (uri.Port <= 0 ? 587 : uri.Port) + "/?starttls=always");
- client.Connect(uri);
- if (!string.IsNullOrEmpty(m_username) && !string.IsNullOrEmpty(m_password))
- client.Authenticate(m_username, m_password);
- client.Send(message);
- client.Disconnect(true);
- finally
- var log = Encoding.UTF8.GetString(ms.GetBuffer());
- if (!string.IsNullOrWhiteSpace(log))
- Logging.Log.WriteProfilingMessage(LOGTAG, "SendMailResult", Strings.SendMail.SendMailLog(log));
- lastEx = null;
- Logging.Log.WriteInformationMessage(LOGTAG, "SendMailComplete", Strings.SendMail.SendMailSuccess(server));
- break;
- lastEx = ex;
- throw lastEx;
- #endregion
This file has been truncated. show original
