I ran duplicati for a while and was regularly backing up to GCS. I pulled up my configuration and I restored the config on a different machine.
I repaired the database and which took forever, then when I went to restore some of the files, I keep getting errors.
2022-06-09 17:00:34 +00 - [Warning-Duplicati.Library.Main.Controller-UnsupportedOption]: The supplied option --auth-username is not supported and will be ignored
2022-06-09 17:00:34 +00 - [Warning-Duplicati.Library.Main.Controller-UnsupportedOption]: The supplied option --auth-password is not supported and will be ignored
2022-06-09 17:48:07 +00 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-RestoreFileFailed]: Failed to restore file: "/source/G0010083.JPG". Error message was: Could not find file "/source/G0010083.JPG"
"RestoredFiles": 0,
"SizeOfRestoredFiles": 0,
"RestoredFolders": 0,
"RestoredSymlinks": 0,
"PatchedFiles": 0,
"DeletedFiles": 0,
"DeletedFolders": 0,
"DeletedSymlinks": 0,
"MainOperation": "Restore",
"RecreateDatabaseResults": null,
"ParsedResult": "Error",
"Version": "2.0.6.3 (2.0.6.3_beta_2021-06-17)",
"EndTime": "2022-06-09T17:48:07.765625Z",
"BeginTime": "2022-06-09T17:00:34.81096Z",
"Duration": "00:47:32.9546650",
"MessagesActualLength": 5,
"WarningsActualLength": 2,
"ErrorsActualLength": 3,
"2022-06-09 17:00:34 +00 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Restore has started",
"2022-06-09 17:00:36 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Started: ()",
"2022-06-09 17:02:03 +00 - [Information-Duplicati.Library.Main.BasicResults-BackendEvent]: Backend event: List - Completed: (158.51 KB)",
"2022-06-09 17:47:54 +00 - [Information-Duplicati.Library.Main.Database.LocalRestoreDatabase-SearchingBackup]: Searching backup 0 (4/17/2022 6:00:00 AM) ...",
"2022-06-09 17:48:07 +00 - [Information-Duplicati.Library.Main.Operation.RestoreHandler-RestoreFailures]: Failed to restore 3 files"
"Warnings": [
"2022-06-09 17:00:34 +00 - [Warning-Duplicati.Library.Main.Controller-UnsupportedOption]: The supplied option --auth-username is not supported and will be ignored",
"2022-06-09 17:00:34 +00 - [Warning-Duplicati.Library.Main.Controller-UnsupportedOption]: The supplied option --auth-password is not supported and will be ignored"
"2022-06-09 17:48:07 +00 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-RestoreFileFailed]: Failed to restore file: \"/source/G0010083.JPG\". Error message was: Could not find file \"/source/G0010083.JPG\"",
"2022-06-09 17:48:07 +00 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-RestoreFileFailed]: Failed to restore file: \"/source/G0010084.JPG\". Error message was: Could not find file \"/source/G0010084.JPG\"",
"2022-06-09 17:48:07 +00 - [Error-Duplicati.Library.Main.Operation.RestoreHandler-RestoreFileFailed]: Failed to restore file: \"/source/G0010085.JPG\". Error message was: Could not find file \"/source/G0010085.JPG\""
"RemoteCalls": 1,
"BytesUploaded": 0,
"BytesDownloaded": 0,
"FilesUploaded": 0,
"FilesDownloaded": 0,
"FilesDeleted": 0,
"RetryAttempts": 0,
"UnknownFileSize": 0,
"UnknownFileCount": 0,
"KnownFileCount": 162313,
"KnownFileSize": 4255648072677,
"LastBackupDate": "2022-04-17T06:00:00+00:00",
"BackupListCount": 1,
"TotalQuotaSpace": 0,
"FreeQuotaSpace": 0,
"AssignedQuotaSpace": -1,
"BeginTime": "2022-06-09T17:00:34.810963Z",
"Errors": null
What should I try? The back up is pretty large pretty close to 4TB. Any thoughts on what patterns I can use to fix this?
