I’m a newbee, running Duplicati v2.05.111 on a Win7-laptop.
When testing a new configuration, after install
I created a backup-Job and testing my storage (Mega.nz) was succesfull.
But running the backup-job was NOT succesful, so I switched to commandline
but when running Duplicati.commandline.exe the result is an error.
See the screen display below:
"C:\batch>“C:\Program Files\Duplicati 2\Duplicati.Commandline.exe” backup “mega://MEGA_BU?auth-username=emailaddress0gmail.com&auth-password=xxxxx” “Z:\BU202047FPSxdisk\X16file” --backup-name=BU --dbpath=“C:\Users\Username\AppData\Local\Duplicati\WHXLJWMCSZ.sqlite” --encryption-module=aes --compression-module=zip --dblock-size=50MB --passphrase=xxxxxxxxxx --keep-versions=1 --disable-module=console-password-input
Backup started at 4-12-2020 12:34:56
code = Busy (5), message = System.Data.SQLite.SQLiteException (0x800007AF): database is locked
database is locked
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at Duplicati.Library.Main.Database.ExtensionMethods.ExecuteScalarInt64(IDbCommand self, Boolean writeLog, String cmd, Int64 defaultvalue, Object values)
at Duplicati.Library.Main.Database.LocalDatabase…ctor(IDbConnection connection, String operation)
at Duplicati.Library.Main.Database.LocalBackupDatabase…ctor(String path, Options options)
— End stacktracing from last location where exception occurred —
at Duplicati.Library.Main.Controller.<>c__DisplayClass14_0.b__0(BackupResults result)
at Duplicati.Library.Main.Controller.RunAction[T](T result, String& paths, IFilter& filter, Action1 method) at Duplicati.Library.Main.Controller.Backup(String[] inputsources, IFilter filter) at Duplicati.CommandLine.Commands.Backup(TextWriter outwriter, Action
1 setup, List1 args, Dictionary
2 options, IFilter filter)
at Duplicati.CommandLine.Program.ParseCommandLine(TextWriter outwriter, Action1 setup, Boolean& verboseErrors, String[] args) at Duplicati.CommandLine.Program.RunCommandLine(TextWriter outwriter, TextWriter errwriter, Action
1 setup, String args)
Any suggestion how to solve the error ?
