Thank you for the awesome job done with Duplicati.
I use OVH Openstack simple storage, and there’s a minor issue when modifying existing backup conf.
When I open an existing conf, the files “OpenstackAuthURI” goes back to “Rackspace US” value.
Thanks for reporting. I think this is the same problem that was reported for S3. It is probably something with the load order, such that the list of servers is loaded after the setting is being applied, and this causes the UI to reset.
