Box.com is discontinuing support for TLS1.1 as of March 31, 2020 and has warned that box compatible apps will fail to login in varying ways if they are dependent on that. I’m wondering if the 2.0.5.1_beta_2020-01-18 supports TLS1.2+ or only supports TLS1.1?
Duplicati doesn’t do its own TLS, but Windows 10 should do fine. Older ones might need help. On Linux, you need mono to be version 5 or above anyway for Duplicati 2.0.5.1, and that will get you past TLS 1.1.
