I set up a task to backup my data to OneDrive cloud. This works fine in Duplicati 2.0 Web interface.
Then I exported the the backup job to the Command-line and stored it to a file “backup.cmd”.
Executing this backup.cmd (with or without administrator priviledges) however fails giving a message similar to
Backup started at 02.11.2020 17:57:43
Checking remote backup …
- Listing remote folder …*
Fatal error => Autorisation with OAuth Service failed: Invalid authid in query. Try to generate an new AuthID Token
I generated an new AuthID Token a couple of times, but the problem persists.
I´m using Windows 10 Pro x64, version 20H2 build 19042.610 (most current version).
What can I do to get this backup.cmd working?
