I really like Duplicati and have been using it for years – thank you for that.
Now, I have installed version 2 on a new win10 computer and every couple of days it hangs on a daily job to backup around 15GB to S3.
Symptoms:
- Message: "Counting (1334 files found, 5.70 GB) " – the entire backup is around 15GB and >10k files.
- Large CPU load ~40%
- No progress
- Quitting and restarting Duplicati doesn’t help
- Restarting the entire computer helps
Any idea of what I should do?
General question: Is it better / more efficient to split a backup in smaller pieces?
Thank you for your support!
