My backup freeze regularly for ten minutes or more with CPU usage but no disk usage. My backend is a local harddisk. I also checked the file handles of the duplicati.server process with process explorer and at during the freezes it isn’t reading any files form the source of the backup.
Here is the verbose log:
* Sep 8, 2019 12:17 PM: All backups to delete:
* Sep 8, 2019 12:17 PM: Backups outside of all time frames and thus getting deleted:
* Sep 8, 2019 12:17 PM: Backups to consider: 07/09/2019 23:17:37, 07/09/2019 22:00:01, 06/09/2019 23:18:16, 01/09/2019 20:36:30
* Sep 8, 2019 12:17 PM: Time frames and intervals pairs: 7.00:00:00 / Keep all, 31.00:00:00 / 1.00:00:00, 59.00:00:00 / 2.00:00:00, 365.00:00:00 / 7.00:00:00
* Sep 8, 2019 12:17 PM: Start checking if backups can be removed
* Sep 8, 2019 12:17 PM: Backend event: Put - Completed: duplicati-20190908T095437Z.dlist.zip.aes (5.53 MB)
* Sep 8, 2019 12:17 PM: Backend event: Put - Started: duplicati-20190908T095437Z.dlist.zip.aes (5.53 MB)
* Sep 8, 2019 12:17 PM: Backend event: Put - Completed: duplicati-i61b0873b3cbb4a9794cc1ed907abf619.dindex.zip.aes (138.72 KB)
* Sep 8, 2019 12:17 PM: Backend event: Put - Started: duplicati-i61b0873b3cbb4a9794cc1ed907abf619.dindex.zip.aes (138.72 KB)
* Sep 8, 2019 12:17 PM: Backend event: Put - Completed: duplicati-bbfc221c957514f2ba8530a1eb04721b6.dblock.zip.aes (39.56 MB)
* Sep 8, 2019 12:17 PM: Backend event: Put - Started: duplicati-bbfc221c957514f2ba8530a1eb04721b6.dblock.zip.aes (39.56 MB)
* Sep 8, 2019 11:58 AM: Skipped checking file, because no metadata was updated C:\Users\Zinoo\.cisco\vpn\log\UIHistory_20190824_223151_log.txt
* Sep 8, 2019 11:58 AM: Including path as no filters matched: C:\Users\Zinoo\.cisco\vpn\log\UIHistory_20190824_223151_log.txt
* Sep 8, 2019 11:58 AM: Adding directory C:\Users\Zinoo\.cisco\vpn\log\
* Sep 8, 2019 11:58 AM: Skipped checking file, because no metadata was updated C:\Users\Zinoo\.GoLand2019.1\config\codestyles\Default.xml
* Sep 8, 2019 11:58 AM: Including path as no filters matched: C:\Users\Zinoo\.GoLand2019.1\config\codestyles\Default.xml
* Sep 8, 2019 11:58 AM: Adding directory C:\Users\Zinoo\.GoLand2019.1\config\codestyles\
* Sep 8, 2019 11:58 AM: Skipped checking file, because no metadata was updated C:\Users\Zinoo\.GoLand2019.1\config\options\window.manager.xml
* Sep 8, 2019 11:58 AM: Skipped checking file, because no metadata was updated C:\Users\Zinoo\.GoLand2019.1\config\options\usage.statistics.xml
* Sep 8, 2019 11:58 AM: Skipped checking file, because no metadata was updated C:\Users\Zinoo\.GoLand2019.1\config\options\updates.xml
* Sep 8, 2019 11:58 AM: Including path as no filters matched: C:\Users\Zinoo\.GoLand2019.1\config\options\window.manager.xml
I know that more logs are probably required so some guidance can be helpful to get those
