Hi
As of about a week ago, my backup is failing with a “Detected blocks that are not reachable in the block table” error.
I’m running Duplicati - 2.0.3.3_beta_2018-04-02 on a Win7 32 bit system.
I couldn’t find an answer in the FAQs.
How can I fix this error?
Thanks
doodlesquit
Does no-one have any idea about this? Can anyone point me in the right direction?
It would be much appreciated.
Thanks
OK, I did another search for the same error, and this time, found something similar.
I solved my problem by doing a recreate under DB maintenance, then a repair, then everything was back to normal and I can now continue backing up.
