Hello
I’m getting this message after completing the backup.
I see that the backup was performed, should I worry about these alerts?
Thank you
Anderson
DeletedFiles: 2
DeletedFolders: 0
ModifiedFiles: 0
ExaminedFiles: 18202
OpenedFiles: 0
AddedFiles: 0
SizeOfModifiedFiles: 0
SizeOfAddedFiles: 0
SizeOfExaminedFiles: 46794180288
SizeOfOpenedFiles: 0
NotProcessedFiles: 0
AddedFolders: 0
TooLargeFiles: 0
FilesWithError: 0
ModifiedFolders: 0
ModifiedSymlinks: 0
AddedSymlinks: 0
DeletedSymlinks: 0
PartialBackup: False
Dryrun: False
MainOperation: Backup
CompactResults:
DeletedFileCount: 0
DownloadedFileCount: 0
UploadedFileCount: 0
DeletedFileSize: 0
DownloadedFileSize: 0
UploadedFileSize: 0
Dryrun: False
MainOperation: Compact
ParsedResult: Success
EndTime: 09/04/2018 19:34:09 (1523313249)
BeginTime: 09/04/2018 19:33:54 (1523313234)
Duration: 00:00:14.0659910
Messages: [
2018-04-09 19:33:23 -03 - [Information-Duplicati.Library.Main.Controller-StartingOperation]: The operation Backup has started,
2018-04-09 19:33:54 -03 - [Information-Duplicati.Library.Main.Operation.DeleteHandler-DeleteResults]: No remote filesets were deleted,
2018-04-09 19:34:09 -03 - [Information-Duplicati.Library.Main.Database.LocalDeleteDatabase-CompactReason]: Compacting not required
Warnings:
Errors:
BackendStatistics:
RemoteCalls: 8
BytesUploaded: 2004983
BytesDownloaded: 54384135
FilesUploaded: 3
FilesDownloaded: 3
FilesDeleted: 0
FoldersCreated: 0
RetryAttempts: 0
UnknownFileSize: 0
UnknownFileCount: 0
KnownFileCount: 2046
KnownFileSize: 51478865782
LastBackupDate: 09/04/2018 19:33:23 (1523313203)
BackupListCount: 34
TotalQuotaSpace: 0
FreeQuotaSpace: 0
AssignedQuotaSpace: -1
ReportedQuotaError: False
ReportedQuotaWarning: False
Messages: [
Warnings:
Errors:
DeleteResults:
DeletedSets:
Dryrun: False
MainOperation: Delete
BeginTime: 09/04/2018 19:33:51 (1523313231)
Duration: 00:00:17.2225280
Messages: [
Warnings:
Errors:
RepairResults: null
TestResults:
MainOperation: Test
Verifications: [
Key: duplicati-20180409T223323Z.dlist.zip.aes
Value: ,
Key: duplicati-i74bc860062f44582980a63f9f945404d.dindex.zip.aes
Value: ,
Key: duplicati-b9048c79c3a2b4a2ead205131572d216a.dblock.zip.aes
Value:
EndTime: 09/04/2018 19:36:43 (1523313403)
BeginTime: 09/04/2018 19:34:17 (1523313257)
Duration: 00:02:26.1675430
Messages: [
Warnings:
Errors:
BeginTime: 09/04/2018 19:33:23 (1523313203)
Duration: 00:03:20.7090510
Messages: [
Warnings:
Errors:
It’s probably not anything to worry about, but the actual warning should be identified. For example, if you were using 7zip instead of zip you’d be getting a warning about potential issues with 7zip (of course this doesn’t apply to you since you ARE using zip).
Try looking at a few of the the job log entries before the last one and see if you find any warnings in there.
Also, be sure to check on the main menu About → “Show log” page under the Stored “tab” and see if it’s maybe a global warning.
