Hello,
I am getting 401 Unauthorized errors to Backblaze B2. I have tried deleting and re-creating the bucket application key, but still get the 401. This connection has worked fine until about June 13th, which is the last recorded log in the Duplicati interface. Even now if I run the backup, I don’t see any new logs showing up in the interface.
The error I’m receiving is
System.Exception: 401 - unauthorized:
at Duplicati.Library.Backend.Backblaze.B2AuthHelper.AttemptParseAndThrowException (System.Exception ex) [0x000b5] in <7e654a6920954d59b0bcb60978e0d789>:0
at Duplicati.Library.Backend.Backblaze.B2AuthHelper.ParseException (System.Exception ex) [0x00000] in <7e654a6920954d59b0bcb60978e0d789>:0
at Duplicati.Library.JSONWebHelper.GetResponse (Duplicati.Library.Utility.AsyncHttpRequest req, System.Object requestdata) [0x000c6] in <21c487eee9024ff385348c90ce2d4189>:0
at Duplicati.Library.JSONWebHelper.ReadJSONResponse[T] (Duplicati.Library.Utility.AsyncHttpRequest req, System.Object requestdata) [0x00000] in <21c487eee9024ff385348c90ce2d4189>:0
at Duplicati.Library.JSONWebHelper.GetJSONData[T] (System.String url, System.Action1[T] setup, System.Action
1[T] setupbodyreq) [0x00024] in <21c487eee9024ff385348c90ce2d4189>:0
at Duplicati.Library.JSONWebHelper.PostAndGetJSONData[T] (System.String url, System.Object item, System.String method) [0x00023] in <21c487eee9024ff385348c90ce2d4189>:0
at Duplicati.Library.Backend.Backblaze.B2.get_Bucket () [0x00039] in <7e654a6920954d59b0bcb60978e0d789>:0
at Duplicati.Library.Backend.Backblaze.B2.List () [0x00031] in <7e654a6920954d59b0bcb60978e0d789>:0
at Duplicati.Library.Interface.BackendExtensions.TestList (Duplicati.Library.Interface.IBackend backend) [0x00000] in :0
at Duplicati.Library.Backend.Backblaze.B2.Test () [0x00000] in <7e654a6920954d59b0bcb60978e0d789>:0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.TestConnection (System.String url, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x000b7] in :0
at Duplicati.Server.WebServer.RESTMethods.RemoteOperation.POST (System.String key, Duplicati.Server.WebServer.RESTMethods.RequestInfo info) [0x00091] in :0
at Duplicati.Server.WebServer.RESTHandler.DoProcess (Duplicati.Server.WebServer.RESTMethods.RequestInfo info, System.String method, System.String module, System.String key) [0x00280] in :0
Any ideas?
