I report below the backup log sent via mail. I don’t know what to do now to repair the backup archives.
Failed: Si sono verificati uno o più errori.
Details: System.AggregateException: Si sono verificati uno o più errori. ---> System.AggregateException: Unexpected difference in fileset 2, found 12810 entries, but expected 12811 ---> System.Exception: Unexpected difference in fileset 2, found 12810 entries, but expected 12811
in Duplicati.Library.Main.Database.LocalDatabase.VerifyConsistency(Int64 blocksize, Int64 hashsize, Boolean verifyfilelists, IDbTransaction transaction)
in Duplicati.Library.Main.Operation.Backup.BackupDatabase.<>c__DisplayClass28_0.<VerifyConsistencyAsync>b__0()
in Duplicati.Library.Main.Operation.Common.SingleRunner.<>c__DisplayClass6_0.<RunOnMain>b__0()
in Duplicati.Library.Main.Operation.Common.SingleRunner.<>c__DisplayClass5_0`1.<<DoRunOnMain>b__1>d.MoveNext()
--- Fine traccia dello stack da posizione precedente dove è stata generata l'eccezione ---
in System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
in System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
in Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__18.MoveNext()
--- Fine della traccia dello stack dell'eccezione interna ---
in CoCoL.ChannelExtensions.WaitForTaskOrThrow(Task task)
in Duplicati.Library.Main.Controller.<>c__DisplayClass15_0.<Backup>b__0(BackupResults result)
in Duplicati.Library.Main.Controller.RunAction[T](T result, String[]& paths, IFilter& filter, Action`1 method)
---> (Eccezione interna 0) System.AggregateException: Unexpected difference in fileset 2, found 12810 entries, but expected 12811 ---> System.Exception: Unexpected difference in fileset 2, found 12810 entries, but expected 12811
---> (Eccezione interna 0) System.Exception: Unexpected difference in fileset 2, found 12810 entries, but expected 12811
in Duplicati.Library.Main.Operation.BackupHandler.<RunAsync>d__18.MoveNext()<---
---> (Eccezione interna 1) System.AggregateException: Si sono verificati uno o più errori. ---> System.Exception: Unable to find log in lookup table, this may be caused by attempting to transport call contexts between AppDomains (eg. with remoting calls)
in Duplicati.Library.Logging.Log.get_CurrentScope()
in Duplicati.Library.Logging.Log.WriteMessage(LogMessageType type, String tag, String id, Exception ex, String message, Object[] arguments)
in Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess.<>c.<Run>b__1_3(String rootpath, String path, Exception ex)
in Duplicati.Library.Utility.Utility.<EnumerateFileSystemEntries>d__23.MoveNext()
in System.Linq.Enumerable.<SelectManyIterator>d__16`2.MoveNext()
in Duplicati.Library.Main.Operation.Backup.FileEnumerationProcess.<>c__DisplayClass1_0.<<Run>b__0>d.MoveNext()
in CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()
---> (Eccezione interna 0) System.Exception: Unable to find log in lookup table, this may be caused by attempting to transport call contexts between AppDomains (eg. with remoting calls)
in CoCoL.AutomationExtensions.<RunTask>d__10`1.MoveNext()<---
Log data:
2018-05-04 00:25:34 +02 - [Error-Duplicati.Library.Main.Operation.BackupHandler-FatalError]: Fatal error
