Ralf
1
Hi Overthere,
great that the new beta is finally live.
Thx a lot for the work
I just noticed that when trying to restore the selection isn’t working as before:
I type my search term e.g. “ebay” and in 2.0.5.1 the tree shows a half green rectangle when the underlying path(s) has(ve) any hits for “ebay”.
Additionally all not applying files and folders on the active level are hidden.
Can anybody confirm? And is it a bug or a feature, meaning I just don’t get it?
Thanks @Ralf. There are some known issues with the restore search filter.
Ralf
3
Yep, I know, that I posted this But this behavior’s different now the in the one before, so I thought it has been worked on.
